im a mobile 1 whore just my preference after trying pretty much all of them and all pretty much equal
Someone told me you can't mix synthetic with regular axle lubricant because it will tear up the gears.I did see where mobil 1 has gl4 and gl5 specs.I did use it one time in a 1998 Ford ranger and the rear end went out.Maybe coincidence. I run Mobil I oil in all my vehicles even the Duramax. Not sure on this axle situation.im a mobile 1 whore just my preference after trying pretty much all of them and all pretty much equal
Drain and fill ull be fine thats like saying u cant run syn oil in your car cuz it will cause all your gaskests to fail lol blah blah blah better is better there are still ppl saying carbs are more effective then fiSomeone told me you can't mix synthetic with regular axle lubricant because it will tear up the gears.I did see where mobil 1 has gl4 and gl5 specs.I did use it one time in a 1998 Ford ranger and the rear end went out.Maybe coincidence. I run Mobil I oil in all my vehicles even the Duramax. Not sure on this axle situation.
I agree, synthetic is the way to go.Drain and fill ull be fine thats like saying u cant run syn oil in your car cuz it will cause all your gaskests to fail lol blah blah blah better is better there are still ppl saying carbs are more effective then fi
Omg she loves it runs so smoothI agree, synthetic is the way to go.
Although I haven't put any in the engine yet, of the P5 anyway.
Just installed mobil 1 75w140.The front housing appears to hold more volume than the rear.I was kind of surprised at that.im a mobile 1 whore just my preference after trying pretty much all of them and all pretty much equal
Well after reading you guys post i bit the bullet this past weekend & changed the rear & front gear oil with motorcraft 75w-140 syn oil and OH WHAT A DIFFERENCE IT MADE-best $22.00 ive spent so far.THIS IS THE BEST WEB SITE I HAVE EVER JOINED----THANKS GUYSFOR THE INFOJust installed mobil 1 75w140.The front housing appears to hold more volume than the rear.I was kind of surprised at that.
glad to help broWell after reading you guys post i bit the bullet this past weekend & changed the rear & front gear oil with motorcraft 75w-140 syn oil and OH WHAT A DIFFERENCE IT MADE-best $22.00 ive spent so far.THIS IS THE BEST WEB SITE I HAVE EVER JOINED----THANKS GUYSFOR THE INFO
Just wait till the aftermarket catches on and we really start building
FINALLY got around to changing the dif fluid and definitely made a huge difference in the rearend noise and thats what i was shooting foryay go me pats on the back lmao
Just got back from a ride in the woods. Wow does she shift smooth now after Mobile 1.Thanks Jak9922.Just installed mobil 1 75w140.The front housing appears to hold more volume than the rear.I was kind of surprised at that.
No.honda says do not use energy saving.Is Mobile 1 Synth. labeled Energy Conserving on the API label?
you wont have an issue swapping it outWhat's the stock diff oil? I'm probably gonna throw my Torq Locker in tomorrow, but the diff only has about 20 miles on it. I'd like to continue to run the stock stuff to allow a good wear/break-in before switching over to some thicker synthetic. Plan is to run it for 3 days at PTO with the stock fluids, then change everything over to synthetic when I get home as it should be well past the 100 mile mark by that time.
