P1000 Money Pit #2
pct
pct
Lost in the hills
790
1,023
Letart WV
Looking good nice work,Thanks for the info
zmnypit
zmnypit
203
270
alabama
Wiring, radio, speakers, light bar, switches all finished over the weekend.
KU0FUE4
TFIFsIc
BAY7bw4
6GRqhZk
OLX0JWh
Test fitting on my buds new trailer getting ready to ride this Saturday.
TVSGlXS
pct
pct
Lost in the hills
790
1,023
Letart WV
Looks like you are gettin it done nice work
Reactions: zmnypit
zmnypit
zmnypit
203
270
alabama
Havent had a lot of time to start any fab work but I did manage two quick and easy additions.
I hear this one is worth 2-3hp.
ImjpAXA
I ordered some vinyl on ebay awhile back and measured all the letters then using my plotter I cut my on decals.
RciUZ5z
E
elkguide
3,377
7,964
Vermont
Most guys find that decal gets you 8 to 10 hp.
(if your rig is RED!!!!!)
E
elkguide
3,377
7,964
Vermont
That sure is a sweet sound!
Sounds good, I’m about to put the HMF on mine because I need room for a rear winch. Hope it’s not annoying like the flowmasters I had on a truck one time.
Reactions: pct
pct
pct
Lost in the hills
790
1,023
Letart WV
I have heard a lot about Cfab lifts pics look good how thick is the material and quality off it can't wait to see how it fits keep us posted from what I have saw on their web site you can't beat his prices on them
zmnypit
zmnypit
203
270
alabama
Initially I was going to build my own but for $125 it wasn't even worth the effort for me to try. Quality is definitely top notch so we'll see Friday how the install goes.
Reactions: pct
pct
pct
Lost in the hills
790
1,023
Letart WV
Keep us posted I have super atv arms thinking about a lift for a little more ground clearance
zmnypit
zmnypit
203
270
alabama
Ok so got the lift installed today. First thing to note is there are no instructions.
If you have a 2017 you will need to remove the push pins that hold the air deflector behind the radiator in place. I used two zip ties, one on each end to hold it up. The other option would be line the bracket up then mark for 3 holes and drill. Decided against that route. Once the brackets we're in place the bolt holes on the new brackets didn't quite line up so I took them off and drilled the front and back holes just a fuzz larger on each end. I opted to use the stock shock bolts for the shock so I also had to drill the outer holes one size larger for the shock bolts to fit. Once that was done front was smooth sailing.
The rear went on no prob. I did end up cutting two spacers down for the top of the rear shock as they were a little long. Overall I'd buy it again for that price. I gained a true 2.5" now with clearance measuring 17".
I also finished up the doors today after having to trim the roof so they would fit.
20171222 111434 20171222 111443 20171222 132805 20171222 133803 20171222 133809 20171222 151029 20171222 151040 20171222 150931 20171222 151004
T
tbaker
371
652
NW. Georgia
Zmnypit where u live in Alabama I saw where u did some riding at Prentice cooper and if u live close enough would u like to do some work on mine when u get thru with yours I live in North Georgia have done some riding at Prentice Cooper
zmnypit
zmnypit
203
270
alabama
About 30mi west of Gadsden off 59. Prentice was right at 2hr from my house
