P700 More Information on Stalling Issues
Hello_Darkness
Hello_Darkness
497
2,085
Just to the right of nowhere
Spent the last week in Georgia at a Technician Competition competing and ofcourse schmoozing with some Honda guys we don't normally get to talk to.
We got on the topic of technical issues with some of the Techline guys who are more directly involved at the dealer level.
The 700 ground issue came up, apparently the ground inside the wheel well gets corrosion inside the wire sheathing several inches. They've had success stripping back to clean wire and attaching the eyelet.
Maybe something to look at if this issue happens to your machine.
DRZRon1
DRZRon1
1,303
4,096
PA
this is good technical no bs stuff for those that have that machine - awesome you do this for everyone!!!
43,492
Thanks for the info!
@Slackjaw
That's the sort of thing I was hoping would eventually come out. Not so much for me...as mine's been fixed for a while, but for those who are fighting it.
The only problem...I'm in AZ. More moisture from washing it than actual water in these parts...but anything's possible.
Maybe some corrosion in the eyelet for me, and the re-crimp fixed it? Or the extra grounds bypass it all together. Been a few years and thousands of miles at this point.
Buckshot07
Buckshot07
23,704
227,031
PA
Why does Honda not protect that area from tire slung mud and water with a plastic shield?
….I’ve thought about fabricating something to protect that area.
Hello_Darkness
Hello_Darkness
497
2,085
The atvs have had the frame ground in the right side rear fender well for over 20 years now.
It's never been a problem for them, so maybe that's the reasoning
Honda did add an additional ground under the front passenger side fender at some point, maybe that's their solution. I know if that ground is loose the unit will idle but die when applying throttle. I've seen it on 2 units customers have installed their own winch and used that ground for the winch but didn't get it tight enough
Reactions: DG Rider
43,492
When was this added?
Hello_Darkness
Hello_Darkness
497
2,085
I'm not sure, the wiring diagram shows an additional ground in 2018 added, but I don't recall seeing that ground under recently, like 2022 or 2023 models. It's easy to see, it's next to the regulator/rectifier under the front fender.
Reactions: DG Rider
43,492
Yeah...I think we've talked about this a few times. Mines a 2020, and there is no ground up by the Reg/Rec unless it's VERY well hidden, so it must have been after that.
Slow Pace
Slow Pace
6
16
Ohio
That's what I decided to do ... I had some plastic cardboard laying around so I cut out a piece and zip tied it... helps keep that area a little cleaner 👍
20231126 114625
