P1000m5 Mud buster's for a P1K5D
This is the difference in the front standard and XL
646dd39d3efa2e807b2eab05d8f138bb
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
Hmmm. When I ordered mine a few weeks ago, they only listed XLs for the rear. Wish I had know they made an XL for the front ...
Ragnar406
Ragnar406
The Great Bald One
4,450
17,034
Bella Vista, AR
I just cut a square piece of rubber and put one slit in it so I could put it around the roll cage. As you can see from the picture it's held in with three of those plastic rivets.
I need to do this - I just installed some and love them so far - the only thing I wish I had done different is to spray some SC1 or other chem that will help with clean up on them while they were new.
Reactions: Koda
These pictures were taken probably over a year ago so things may have changed. They may only offer one style now.
Not sure.
nbomar
nbomar
4,416
17,854
Springdale, AR
Not sure.
What did you use to make the rear extensions?
HDPE textured sheet. I bought some on Amazon for switch plates and these extensions.
Reactions: nbomar
nbomar
nbomar
4,416
17,854
Springdale, AR
Got any small piece left I could use for extensions?
I may, I'll check later in the shop. I also May have some of the rubber stuff that will work also
Reactions: nbomar
I don't have any HD PE. I do have some of that flimsy rubber stuff I used on the bottom it's probably enough to make those little flaps on the back but I don't think it will work too good as it would be too floppy.
This is what I used
50ebd3857e893f8373e107b46d2b3aa7
nbomar
nbomar
4,416
17,854
Springdale, AR
This is what I used
Thanks. I’ll order some!
Reactions: joeymt33
Neohio
Neohio
Beast of the East
17,743
85,614
Painesville Ohio
Try your local dollar store. Check the flexible cutting board section. Cheap enough to try.
Shields
Shields
Louisiana
I love the Mudbusters. I run 12" wide terminators on the back and the Mudbusters have eliminated 98% of mud in the passenger areas. Before I installed Mudbusters we would get hit in the back of head by large chunks of mud.
