The factory installed Digital Dash found on the Pioneer will help keep you informed on the condition, current situation, and expected maintenance through its multi function display. This display offers several indicators: Neutral, Reverse, Parking Brake, Differential Lock, High Temperature, Check Engine, and, Seat Belt indicators.
The dash also offers a main display with the following:
• Gear Position Display, showing what gear the SxS is in.
• 4WD, showing if the SxS is in 4 wheel drive. This will be shown if the diff lock indicator is on.
The multi function “MODE” button allows for the following:
• Speedometer Display, showing the current speed of the SxS. In MPH or KM/H.
• Odometer Display, showing the total lifetime miles/kilometers.
• Trip-Meter, showing the miles traveled during this trip.
• Fuel Gage Display, showing the fuel supply currently in the tank. It will flash “LO FUEL” to indicate reserve level.
• Digital Clock, showing the time as set by the user.
• Coolant Temperature, showing the coolant temp. This is in addition to the HOT indicator light.
• Hour-Meter, showing the total lifetime hours with the ignition in the ON position.
The display also includes a maintenance reminder system showing the following:
• A wrench symbol appears at first 100 miles or 20 hours indicating first service is needed.
• A wrench symbol with a 1 above it appears indicating time for regular maintenance #1 at odd/hundred hours (ex 100, 300, 500… hours)
• A wrench symbol with a 2 below it appears indicting time for regular maintenance #2 at even/hundred hours (ex 200, 400, 600… hours)
