Multi function digital dash info.
rzrmudder
5
15
0
The factory installed Digital Dash found on the Pioneer will help keep you informed on the condition, current situation, and expected maintenance through its multi function display. This display offers several indicators: Neutral, Reverse, Parking Brake, Differential Lock, High Temperature, Check Engine, and, Seat Belt indicators.
The dash also offers a main display with the following:
• Gear Position Display, showing what gear the SxS is in.
• 4WD, showing if the SxS is in 4 wheel drive. This will be shown if the diff lock indicator is on.
The multi function “MODE” button allows for the following:
• Speedometer Display, showing the current speed of the SxS. In MPH or KM/H.
• Odometer Display, showing the total lifetime miles/kilometers.
• Trip-Meter, showing the miles traveled during this trip.
• Fuel Gage Display, showing the fuel supply currently in the tank. It will flash “LO FUEL” to indicate reserve level.
• Digital Clock, showing the time as set by the user.
• Coolant Temperature, showing the coolant temp. This is in addition to the HOT indicator light.
• Hour-Meter, showing the total lifetime hours with the ignition in the ON position.
The display also includes a maintenance reminder system showing the following:
• A wrench symbol appears at first 100 miles or 20 hours indicating first service is needed.
• A wrench symbol with a 1 above it appears indicating time for regular maintenance #1 at odd/hundred hours (ex 100, 300, 500… hours)
• A wrench symbol with a 2 below it appears indicting time for regular maintenance #2 at even/hundred hours (ex 200, 400, 600… hours)
Reactions: Swampcollie
atvsnowman
atvsnowman
23
All that from one button. There is only that one MODE button right?
I'm glad to see the coolant temperature, But I think it is in a bar meter not not temp numbers. Still might be nice to add one so you can see it all the time. I dont under stand this maintenance thing.. wrench 1, 2,3??? Whats the purpose.
greenatv
greenatv
127
31
0
Ya. I don see that one button doing all that. But who knows... I guess it could. I want to learn more about this maintenance thing.
Tundra20
Tundra20
316
812
Arkansas
Hey guys i know this is old post been lookin around this post os all i found but anyway while out riding today my Maintince wrench symbol came on but also a -2 at the bottom what does this mean
I will post picture
Tundra20
Tundra20
316
812
Arkansas
4128DA87 6F64 4B91 9B01 6197DF48C998
63,589
That's how many miles past the maintenance reminder you are.
Push the button and it will cycle threw.
There is a tripmeter and a hourmeter for maintenance. Like a countdown. Or in your case, past due.
Reactions: Russ989
Tundra20
Tundra20
316
812
Arkansas
Also i might add it read -1 for awhile then -2 im sure its in my manual but left it at camp so im just curious
Tundra20
Tundra20
316
812
Arkansas
Ya I cycled thru the modes but had not seen this I figured it was something to do with maintenance any way always learning something i knew someone on here had the answer
thanks
allgm1
allgm1
1,049
1,484
New Hampshire
if/when you do said maintenance and reset the reminder, it will show you the miles before the next maintenance is due. Its a good feature so you can plan ahead and get ready for upcoming maintenance....if you scroll through the menus every now and again.
Tundra20
Tundra20
316
812
Arkansas
Thanks for yals replies will be doing all maintenance myself will change oil soon
CWL23
69
46
Louisiana
I went through my options on my dash and on the last one on the screen by its self it has the coolant symbol and says low. I just bought it brand new only 13 miles on it . Is it anything to worry about.
BillEwing
BillEwing
80
125
kingston springs tn
Great information thank you!!
