I picked up a Bully storage bag on sale for $28 and after trimming off one of the end pockets then a bit of work on the wife's sewing machine to re-install the mounting straps it fit perfectly. Tons of storage and seems to be a good quality product. Zippers are the waterproof rubber covered style.
My next upgrade was to get some better lighting than the stock headlights and a high/low beam option. I built a set of brackets to hold some 7" LED light bars. The lower ones are the flood light version and I installed the same socket plugs as the stock headlight bulbs so I could keep the factory plugs. So now when I turn on the headlight switch it turns on the lower bars. For the top bars I went with the spot light version and connected them to my 9" light bar mounted above the winch so when I want high beams I flick that switch on. It all worked out well and I'm happy with the light output compared to the stock headlights.
Thanks! I did the whole inner fenders with the same stuff to keep the area under the hood from getting soaked with water and mud all the time. It's worked out well.
