P1000 My dual battery diagram/plan.
Alaska350
Alaska350
96
233
Anchorage, AK
I know there is a ton of info on the internet about how to do this but couldn't find any that had the exact set up I want to run so I made my own. I have very few items I want to run initially but like the idea of being prepped for more later on so I have outlined a diagram plan that I would love to get some feedback on since I am by no means an expert. I am gonna install a Auxbeam control panel for the simple on/off stuff just cause it seems super easy lol and then a couple rocker switches that cant be routed through the Auxbeam panel. Thanks guys!
Questions:
  • I have the SxS club add-on ACC harness installed that I plan on having it trigger 3 items, will this be too much? See pic.
  • Do my ground hook up locations matter?
Accessories:
SxS club fan overide
Winch
Horn
Led Lights
Planned accessories:
Heater
Cab Fans
Stereo
Honda Pioneer Dual Battery Diagram
bumperm
bumperm
1,889
6,743
Gardnerville, NV
As long as a ground is essentially the same point electrically as the battery/frame ground, it's good. One thing I noticed is it appears you are powering the winch through a 100 amp circuit breaker. That won't cut it as peak winch current can be almost double that. It is common to wire the winch contactor directly to the battery - - that's the way my '21 SE winch came wired from factory.
66,167
Commend you for NOT running the isolator to the buss bar.
Suggestions:
  • Recommend moving the winch directly to the second battery. Main power and main ground.
  • Fan and horn both need their own inline fuse if your not running them off the Auxbeam.
- The ACC should be used for small draw items or as a trigger wire. There is really no limit for using it as a trigger wire.
- YES, Ground location does matter, it matters ALOT!
Ex, in your diagram, to return winch power to the source for a full loop.... it must travel through the primary battery, through the primary ground wire, to the secondary ground wire, and into the source (second battery). Thus why it should be directly to the second battery.
Dave75
Dave75
123
500
FYI: The Stinger isolator can fail in the cold. I went thru 2 stingers this winter before using a Cole Hersey.
Good job on the dual voltmeter, that is a must have.
Alaska350
Alaska350
96
233
Anchorage, AK
Awesome feedback. So other than moving the winch’s main wires directly to the second battery I am good to go??
Corrected diagram:
7D1373CA 8D19 44C9 9FA8 F4A800FFD4DD
JMynes
JMynes
544
3,237
Augusta, Maine
It looks good except…
Assuming you’re using 6 ga wire to the bus bar, you should use a 50 amp breaker. 6 ga wire is rated for 50 amps. If you were somehow drawing, say, 90 amps off your bus bar the 6 ga wire could overheat, melt the insulation, and short prior to the circuit breaker, thus going Full Polaris.
Circuit breakers and fuses are meant to protect the wiring, and should be sized accordingly.
Alaska350
Alaska350
96
233
Anchorage, AK
Roger that. Running 6 ga so will order a new 50 amp breaker. Thank you sir!
Alaska350
Alaska350
96
233
Anchorage, AK
Finished up the install. Ended up doing away with the red bus bar since everything can run through the aux beam fuse box/panel. I actually like this because I can control the fan override harness via the panel button.I updated the diagram to reflect this. Only issue so far is the volt meter need to chill the hell out as it’s super bright lol.
4848CA33 E02C 4C8A 89BB 9A0D2D8C84A1
CBE472DE 758A 4C7E B129 532BC7E1E10D
12B096A2 A2FF 4AB3 9930 F630C97427C8
9A8BFB41 C4E0 46C7 B010 8590AC6178AA
StewB
StewB
711
3,295
My new favorite phrase: "going Full Polaris."
Kal
Kal
209
737
AZ
I've read that in a few threads, which Cole Hersey did you use?
bumperm
bumperm
1,889
6,743
Gardnerville, NV
Yes even when doing it with two different colors my ocd was twitching. Just what I had on hand.
To be clear here, multi-colored nylon ties DO have a place. They work good for identifying which hydraulic quick-connect hose goes to which place when changing implements on the tractor.
