Myth or Truth? Winch to Trailer
Gator
Gator
The Most Unknown Member
2,488
10,460
Louisiana
I've heard it said many times, that you cannot (should not) use your winch to secure the front of a wheeler/SxS when trailering, because "winches are not made for dynamic loads, therefore you will damage your winch".
I've been doing it since the 80's. One time the cable was pulled tight into the spool, making it difficult to pull out. Otherwise, I've never had an issue.
I park against a hard stop and pull the suspension down about half way.
Have any of you ever personally broken a winch or cable doing this? Or is it an urban legend?
Reactions: sharp
BigOL3
BigOL3
2,994
8,920
I SOMETIMES use the winch to tie the front end down IF only traveling a short distance, but never so tight as to bottom the shocks out. Never had a problem.
Reactions: sharp
70Bones
70Bones
888
3,779
New Brunswick Canada
I've tried to find the logic in that, all I can see is that if you have a winch, let's say, 3000 lb, and you've got your buggy's springs compressed about half way, I'm guessing 500 lbs of winch power, and you go over a bump on the road, and the buggy wants to bounce, could the force on the winch go over 3000 lbs? Is that the load "they" are talking about?
Reactions: sharp
It’s a dynamic load winches and winch ropes are not designed for a dynamic load but a slowly increasing static load.
Spend $$$ on a good set of tie downs and a few mins using them.
Forces generated by dynamic loads can be MANY times the weight of the load itself.
I don’t remember the formulas from physics, but a 200lb man (dynamic load) falling from 10’ can generate a 2000+lb shock, imagine a 2000lb SxS moving 6-12” and how much force it can put on the $200-700 winch.
Now imagine if that SxS tied to a trailer moving at 70mph behind your truck and a bad driver pulls out in front of you. That SxS is going into the cab of the tow vehicle like a 70mph 2000lb wrecking ball.
Edit: That reads very harsh but physics is a cold hearted b****, and no one needs to get hurt over a few dollars in tiedowns and a few mins each time they trailer a machine.
K
kswaterfowler
945
3,528
Kansas
So I am at work and thought about a fall protection demonstration truck they brought out last year and videoed the results. The guy has a 220 lb weight he drops 6 ft without a shock absorber on it. Anybody want to take a guess how many pounds that equates to?
dnjones161
dnjones161
583
1,713
Ohio
North of 1000lbs ?
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Do what you want to most people do. But using your winch to tie your ride down is a bad idea. Don't ask if you don't want to know.
dnjones161
dnjones161
583
1,713
Ohio
Load cell showed 4796 lbs. With a shock absorber only had 745 lbs of force on the load cell. They had always told us while wearing fall protection look for something you think would hold a car.
This is exactly why people that do extreme rock climbing scared the $+#& out of me.
You can't tell me that quarter inch anchor is going to hold into that crack in the rock when you drop 4000 lb of weight on it
ToddACimer
ToddACimer
Pioneer 1005-2
3,678
15,560
Oshkosh, Wi
Couldn't have said it better. I'd never tie down with a winch and you won't convince me to try it. I do love my shock straps for securing my P1000-5.
Rope is dynamic, basically a bungee cord it’s spreads shock out over a longer time frame so instead of 5000lbs in half a second it’s 500 over 5seconds
I couldn’t remember the math I swag’d low.
Reactions: sharp and Vikes79
K
kswaterfowler
945
3,528
Kansas
Depends on the rope. We used a lot of static rope when I was high angle rescue and confined space rescue certified. Climbers use mostly dynamic just for the shock absorption. FWIW I absolutely hated rappelling.
104,857
Straps are cheaper than winchline. Especially if the line is synthetic. If it’s steel, you run the risk of even more damage if it snaps. Like a bullet it will fly and take out other things like windows. Personally I’d say not a good idea. I over strap my machine down when trailering. I use both the Erickson’s or E Tracks and either a strap in front and or the back especially at interstate speeds. Redundancy spending now beats spending more for unforeseen damage later. Then there’s lawsuits.....or if it came off the trailer causing a manure truck to jackknife and so on...like livestock, have ye ever seen 50 cows or 100 pigs ground into the pavement? Mmmmmmm meat. Got Ketchup?....what are we talking about again?
Kilo427
Kilo427
1,543
6,440
I have done it when I thought it needed to be used like on the back of my truck, but if I have good tie downs and correct positioning on them I will use them and just attach the rope loosely in the front as a fail safe.
hondabob64
hondabob64
215
795
Louisiana
59F4B5B4 D1E8 4643 8E92 F716DEC74DAF
6C771020 7E50 43AE 8C85 0BB9C3CF5F10
I use my winch on front & my Trailer Dog on the rear. Lockable & fully secure.
Reactions: sharp
Baldeagle
73
AB
The 2500 warns with the plastic planetary gear. Not a good idea. Others no problem.
Reactions: sharp
hondabob64
hondabob64
215
795
Louisiana
I use Smittybilt winches exclusively. Never a problem whatsoever.
Reactions: sharp
