P500 Myth or truth?
Ragincajun92
Ragincajun92
163
231
Kingsland, Georgia
I have heard of people doing this and wonder if it’s true or not. If you have say a 26” tire, but it’s true measurements are more like 24 3/4”. You can take that tire and put 30 psi in it and leave it in the hot sun for a few hours and then let the air back out to 5psi or so and the tire will measure 26” or bigger from doing this. Just wondering is this really true or a old legend
Reactions: rocmar
I’ve “heard” some of the bias ply tires will “stretch”, but it’s only been “posted on the internet by a friend of a friend’s dog sitter’s 3rd cousin’s taxidermist’s pool boy’s 4th ex-wife’s divorce attorney” and you know how dependable attorneys can be.
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
I know a guy that uses that attorney.
Seriously, I've had a 4-wheeler tire develop a "bulge" in the sidewall. I blamed the bulge on leaving it parked with 30 PSI in the tire. You can try to stretch it, but be aware that too much pressure or "stretching" is unpredictable.
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
if running a multiple ply or belted tire(all modern tires) this will not work unless you break the belts in the tire and that is not good. Back in the old days before modern tires you could do this.
rocmar
rocmar
4,741
5,776
4 CORNERS
I think...psi..determines. ..height
of tire..a 26"tire....is not 26"
...with 4psi..in it,,
most tires read true height..
....with max psi..
Max ..psi on maxxis Ceros
...is 18 psi...at 10 psi...I'm
25"
Reactions: mrjeff42 and Mudder
Twangin
Twangin
131
276
NC
I wondered the same thing and was really skeptical about it.. asked the folks up here in one of my threads and the general consensus is no. I’m sure they might could stretch a tad, but nowhere near an inch or two. The best bet is to order a size taller than the target size and run psi to what rides comfortable.. at least that’s what I did. We’ll see how that works out in a few days when my tires/wheels come in
