Only batteries we run in the fleet, good batteries. Battery Outfitter is good, but you need to watch which group size they sell you, my original lasted four years, the one from BO lasted two, wrong size group.Anyone have any experience with Napa batteries?
What size group am I looking for? My factory battery is a gyz16h, the Napa battery has a 14 in the number. My last pioneer, I ordered a battery with a 14 in the numbers, and it half the size of the original. But when looking up part numbers, they all call for batteries with a 14.Only batteries we run in the fleet, good batteries. Battery Outfitter is good, but you need to watch which group size they sell you, my original lasted four years, the one from BO lasted two, wrong size group.
Do some checking? There will be some expert battery member experts by in a little.What size group am I looking for? My factory battery is a gyz16h, the Napa battery has a 14 in the number. My last pioneer, I ordered a battery with a 14 in the numbers, and it half the size of the original. But when looking up part numbers, they all call for batteries with a 14.
I’ve been researching it, but can’t find a clear answer.Do some checking? There will be some expert battery member experts by in a little.
I'm no expert but this is the one I replaced the original with. Works great!Do some checking? There will be some expert battery member experts by in a little.
I was on the Club Store site today and reading about the dual battery config and mixing the pri. lead batt with the second lith. battery, if @Hondasxs sees this he can shed some knowledgeable insight into this.Call your local napa, the counter guys get paid to figure out what battery you need.
Just confirm polarity before hooking up. Recently another member installed a battery with the posts reversed and smoked a 20 fuse.
I’m looking for another agm for use in a dual battery setup.I'm no expert but this is the one I replaced the original with. Works great!
Fire Power Featherweight Lithium Battery - Cycle Gear
In the racing world a lithium battery is one of the simplest ways to drop weight and save space in your motorcycle. Fire Power has taken this same lig…www.cyclegear.com
I was hoping to find a replacement without taking the original out. But it’s looking like that’s what I’ll have to do.Power sports batteries are a PITA to figure out. I usually take the ‘bad’ battery to Sam’s Club and start opening boxes to compare.
The numbers on the battery don’t seem to correlate between brands, nor do they indicate physical size.
Same number as the Autzone replacement. Cuz there both made by Exide.ETX14
Wish I’d known that last night.The NAPA replacement battery for the Pioneer 1000 is numbered ETX14.
It's an AGM battery. I have run mine two seasons now (with a Mighty Max as an aux battery) with good performance.
