W
My friend has a two seater Talon. I don't have access to it at the moment. I am trying to build a simple antenna mount so he can test out a GMRS radio. I don't want to do any hole drilling on his machine at this point. I am using stuff I have on hand in my garage.
I think I can mount aluminum flat stock to the bolt that holds the rear center of the roof. The bar would simply extend back from that bolt with an antenna mounted on the end of it. I am hoping to just attach this at the staging area prior to riding. So it's "quick and dirty". Can someone grab me a few simple measurements?
I attached an image for what I am referencing. The tip of the red arrow is the bend in the bracket holding the roof. The tip of the orange arrow is the rear end of the plastic roof.
I assume the yellow circled bolt is probably a 6 mm bolt? (10mm wrench size)?
What is the distance from the tip of the red arrow to the center of the bolt?
What is the distance from the tip of the red arrow to the tip of the orange arrow?
Thank you!
Thank you!
