Multi Need a Floor Jack - What is best for Side by Side
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I am looking to buy a floor jack. Not sure what type to buy. They have the ATV/Motorcycle jacks, but not sure that would be the best. The regular floor jacks seem fine, but not sure.
What type of jack do you find to be the best for the side by side...
Reactions: sharp
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
I dont know if its the "best" for a sxs..but it works good.
NWMDC
Floor Jack 3.5 Ton
115,793
I bought a Harbor freight floor jack - just figure out how high you need it to lift and look at their specs
I have 2 of them. You can't beat them, there good quality and if you look you'll find them on sale and you can use the 20% off coupon in the back of
Most magazines on them as well
Tramguage1
Tramguage1
Texan
7,479
30,609
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I brought it for my 50th birthday. I used it a LOT while i was building my Daihatsu rock crawler. Must have removed and reinstalled the body 100 times atleast.
Im getting to old to get up off the floor when i get down there.
The ideal way is called a bridge jack.. there is a track on the inside of the runners and the jack slides/rolls back and forth where needed.
IMG 5136
But there are also cheaper alternatives.. you can do with jack trays
IMG 5138
IMG 5137
nbomar
nbomar
4,416
17,854
Springdale, AR
Bridge jack... that’s what we had on ours. 2 of them. Worked ok. Somethings are still better on the 2 post racks.
Reactions: Deluxe700 and sharp
115,793
That's what we had when I worked at Roush. The hoist works great for heavy truck. The bridge jack Is like @nbomar said "ok" but works, you'll need a powerful 2 stage compressor to operate it under load. The worst crapy part is when you needed to work on anything that was near the Ramps the vehicle is sitting on. Bruised the hell out of my ribs or legs trying to reach those areas of the car/truck depending on the hoist position.
Reactions: Ragnar406 and sharp
