P1000 Need a little help.
Bucks
Bucks
23
94
Indiana
  2. Looking to buy
  3. 700-4
So, I have the auto headlight trigger from the club store. I am running a bigger light bar on it, so using the relay that came with it. My question is, it came with a rocker switch already wire in. So right now I have to have the rocker on and then hit the high beam switch for the light bar. Needless to say I want to eliminate the rocker and just use the high beam switch. But if I unhook the rocker switch then it doesn't get power. Do I need to just order a 4 post relay to eliminate the rocker switch or is there a different way to wire this? I have just enough experience with wiring and relays to be dangerous, so dumb it down for this old hillbilly. Maybe @Hondasxs can answer this, or @joeymt33 as I read in his Traveller 2 build he used a relay with the auto trigger. Any help is greatly appreciated. Thanks!!
Reactions: Remington
115,686
Id help you, but you tagged the right smellers that will have a quicker insite for you. They will be along soon.
Bucks
Bucks
23
94
Indiana
  2. Looking to buy
  3. 700-4
Thanks Remington, I have faith they have an easy answer.
66,867
What color are the wires going to the rocker switch?
Bucks
Bucks
23
94
Indiana
  2. Looking to buy
  3. 700-4
I will have to look when I get home. Give me a couple hours and I will let you know.
66,867
One will be black.
One will be HOT 12v+
One will be a relay trigger wire.
Identify which one is the trigger wire and hook it to the high beam trigger red.
Bucks
Bucks
23
94
Indiana
  2. Looking to buy
  3. 700-4
One will be black.
If I'm not mistaken, the wires were white, black and a blue one.
Bucks
Bucks
23
94
Indiana
  2. Looking to buy
  3. 700-4
I'm guessing the trigger wire is the blue?
16783918577871017604574955634807
