Ridinfool
Ok, I'm adding some stuff to the buggy, 8" under seat fan and 4 -4" cube lights (2 on back and 2 on front) I've got a fuse block with ground and a 6 panel switch to turn them on/off was not going to do a second battery but then decided it would be better if I did. I will be wiring it so the switch panel will only work when key is on. My question is do I really need a second battery? The only other power accessory I have is my winch. Not really planning on adding anything else other than what's listed above. This is the battery I'm using and the solenoid what isolater kit do I need and is that all I need to make this happen? Wife wants to know where does it end?!?!?
Of course I gave the only logical answer... it doesn't. Lil help please, with the battery thing not the wife😁
