P700 Need help with tires and lift
WagginTail
WagginTail
1,604
5,921
SC
20201112 172010
20201112 172000
Turned out pretty good. Huge difference from stock tires.
WagginTail
WagginTail
1,604
5,921
SC
So I took the strongmade lift off the front just to check the ground clearance difference with and without. So with 2" puck lift and the strongmade I had 13" ground clearance. Took the strongmade off and left the puck lift on and had 13.5" ground clearance but my tires rubbed worse in off camber situation. These measurements are at bottom of frame at the front and with the 28" blackwaters on at 10 psi.
WagginTail
WagginTail
1,604
5,921
SC
I have 14.5" of ground clearance at the back with just the strongmade lift
WagginTail
WagginTail
1,604
5,921
SC
Does anyone know if I will be ok using stock tire and wheel for a spare? Didn't know if the height difference would tear something up.
