P1000 Need help with Viper widespool install on P1000-3
338fedman
17
36
Alaska
I got my winch in the mail and looking over what it will take to install and looks like a real pain. The contactor that comes with the Viper is taller than the existing warn winch contactor and it don't think it will fit where the existing contactor is located (behind the 2nd battery). Where did other mount the contactor? And, i assume I could just replace the winch and use all the existing winch wiring and switches currently in place, other than I would lose the wireless controller. Any help is appreciated! Thanks.
Jankyeye
Jankyeye
838
4,031
Tampa, Fl.
Far left in the picture,
EA76898C A16F 406D A03E 471359EAB1ED
Dezrik
Dezrik
Follow me for adventure!
297
956
MOAB, Utahhhhhhhh
I have no pictures but I installed mine on the drivers side next to the battery.
208,728
I left the Honda contact and put the battery leads on my secondary battery, don't know if that's right or wrong, used the factory wiring for the winch, installed a toggle for in and out, haven't changed out the remote yet. I've got to trace that out.
338fedman
17
36
Alaska
Thanks for all the responses. I think i'll just try changing out the winch and use the existing wires for now. Maybe I can still wire in the wireless transmitter to the existing set up? Has anyone else done that?
208,728
Not yet.
Jankyeye
Jankyeye
838
4,031
Tampa, Fl.
I have a hersee relay behind the 2nd battery, hard to see in the jumble of wiring.
208,728
I already used that spot for my stinger on the dual battery set up, which it doesn't look like you have one.
I have a simplistic mind, so I connected the winch direct to the secondary battery and ran power to a Blue Ray fuse block from the secondary battery, every accessory has it's own ground from the fuse block and fused positive power.
Reactions: packer58 and CID
208,728
Winch not direct, from the contractor.
Reactions: CID
Jankyeye
Jankyeye
838
4,031
Tampa, Fl.
I like how you labeled all the wires....i wish i did that for all of them:(
I wish I had a better plan from the start and could have made it neat and organized. Maybe one day I’ll get bored enough to start over and make it pretty.
  • Haha
Reactions: CID and Smitty335
