Need mud flares
G
Georgiaboy
185
719
Big tires mean bigger mud guards, looking for something good but not too expensive, seen kemimota had a set for 120 anyone used? Or do I need to pony up to the mudbusters? Advice please
P
pappyo
593
2,377
If your going ( DYI ) method check Out attached post::
Online at :
SpeedwayMotors.com
Airdam/Body extention Plastic
1/8in Thick x 22in. Wide x 25ft. Long roll. SMOOTH texture
Black was under $75.00 shipped to door ( guarantees 2 Day Del. )
Other Colors & lengths available.( $$$$ varies)
Durable & Flexable -- stiff enough to hold desired shape using a heat gun.
Easy to work with -- Heat Gun -- tin snips & or sabersaw.
Only your imagination & fabricaton skills is holding you back.
Mud Guards
Fender Flair's
P520 Box area above & in front of Rear Tires (prevent mud build-up up )
P500 Floor protcctors ( P700 too )
Unlimited uses! Atv/UTV-- trailer -- Truck
LESS -- $$$$ than 1 set flairs or mud guards
View attachment 322476 View attachment 322478
F
fartsalot
223
337
I made mine from this same material except I bought it from a local speed shop and did not half to buy such a large quanity. I made a pattern out of stiff rigid paper and made changes I wanted and traced it out on the plastic. Only down side the plastic is a little flexible out on the end in the back but if I clip a tree it does not break but just bends out of the way. I even plugged the simulated air vents on the upper side towards the back so they do not fill up with mud and I made inner fender liners for the rear in front to the back tires where the open cavity is. Took a little time making it but enjoyable time spent in the shop with my buggy Total cost about 25 or 30 bucks.
104,959
Which ones you recommend
Mud busters, they saved my ass from getting mud shot down my neck.
A2C2227A 64CD 4E51 BF82 BB11F4CA00DA
