The cases are the same size.Thanks Have you installed the XS battery yet? Is there room for the extra height in the battery box?
How long did the original battery last? What were the signs that you needed a new one - slow cranking or just preventative maintenance/caution?Got the XS power battery installed. Seems like a quality piece. Threaded brass terminals, stainless hardware. 330cca, 22ah, 2 year warranty. Only issue was making the Honda cable fit on the terminals. XS power send some spacers to allow for the shape of the Honda terminal ends to connect to the battery terminals but they are not quite thick enough so had to straighten the little 90º bend on the inside of the cable terminal a bit to get it to work. No big deal. Will see how it performs.
I agree, batteries are a bad place to cut corners, especially on an 'outback' vehicle (sitting in the RV in the Utah desert right nowLittle over 2 years. More preventative maintenance than anything. I've noticed on the last few rides that even though the voltage didn't look too bad it was slower cranking. I'm "that guy" when it comes to this stuff. Not taking any chances. I do keep the Talon on a maintainer when it's not being ridden.
I pretty much keep maintainers on everything that sits for very long. Kind of a double edged sword though because as I'm sure you know the maintainer can mask a battery going bad. Thus the change out to be safe rather than sorry.I agree, batteries are a bad place to cut corners, especially on an 'outback' vehicle (sitting in the RV in the Utah desert right nowwaiting for the frost to melt before doing an oil change. The miles just keep adding up when yer retired.
) I just replaced the house batteries on my RV because they weren't quite as perky as they were just a year ago. Thanks for adding that you use a maintainer.
when I went to put my Talon up for summer storage last spring the battery was dead. I don't use a battery tender in AZ because it is so hot. I just disconnect the neg cable for storage. All my other batteries I use tenders on with good success. My 2008 RZR 800 in Michigan had a 10 year old battery that I replaced just because it was so old..
What brand Lithium batteries have you used?
