P1000 Need to stay same as OEM width...
V
vitulla
11
Montreal, Quebec, Canada
Hey guys
300 miles and punctured A deluxe tire already...
Looking at changing all tires and maybe wheels but absolutely cannot be wider then 64"
I was thinking of going 28-10-14 all around so I can also have a spare, don't mind running spacers in the rear to bring them out like the fronts. What wheel setup would I need? Looking at tusk terrabites as tires.
Thanks
68,409
Your looking at a 1/2" on each side and you are at 64. Not much play in your requirements.
Switching to anything outside factory rims is most likely going to be pushing 64.
Normally everyone runs a 7" rim with a 2-5 offset. This will overstep 64.
Another option is a 1-6 offset. But then you may run into clearance issues in the front as you are pushing the tire into the fender well.
Reactions: CumminsPusher
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
Just put 28's on your steel wheels and have fun. That's what I did and haven't found anywhere the other boys go that I can't. Blackwater Evolutions in 28x12.... Great tires
V
vitulla
11
28-10-14? Wouldn't bumping up the fronts to 10's make me 2 inches wider and therefore be around 64.9 inches?
Sorry for all the questions, being from Canada I will most probably be ordering from the US and cannot make a mistake or it will cost big bucks sending back
Eltobgi
Eltobgi
4,599
15,187
North Dakota
I was curious on the setup you were running in the videos. But I have to say there is a certain level of skill involved in you making it where the others do! ;)
W
wyodlr
147
209
Cody Wyoming
Try putting your rear tires on the front and measure it
68,409
If you stick with oem and jump to a 10" front that would only be adding 1 inch. Not 2.
1/2 each side center of the wheel.
Rears would be less.
