New 520 pioneer
Flinterboy247
Flinterboy247
12
67
Ontario, Canada
Congrats and welcome. Is the dump box an assisted lift, and if so what pounds is it rated for on lift? With the 2500 winch, suggest a pulley in case you need a double line pull.
Can you post a pic of the under box frame and attachment points? Thanks.
Thanks, glad to be part of the club. The dump box is rated for 450lbs load, as far as tilt assist strength I couldn’t find any real numbers but it’s a single cylinder shock, just a bit bigger than what you’d find under the hood of your car. The pivot point seems to be in a nice spot so tilting a 450lb load wouldn’t be a great effort. The bed of the box seems durable enough with several tie down rings. The pulley you suggested is for mechanical advantage because the 2500lb winch is on the small side or is it for something else?
3BB221BA CF1E 4337 94F8 748E3C3D5B6E
CF7FD622 4105 48ED A045 6301AA5F373A
B854D69F C2CB 48FC BB44 38AE4DD23817
B2D2A371 76B0 4284 8C28 941E72A0A385
E36F5FD2 4098 46A2 B672 F6F63C0916CC
BBD3A120 6A04 4679 A967 D3AB3F22A15B
B0B34705 9048 46DB A0EE A37FA12F835F
1EDCDCAF 98EF 4720 8D38 4D1BE47AAE64
Mudder
Mudder
NTC Ambassador of Walls
11,691
88,486
Thanks for the pics @Flinterboy247 . Those satisfy some curiosity for sure. And yes, I was suggesting a winch pulley because the 2500 lb winch is on the smaller range, especially in deep mud, but a pulley will double the pull. Somewhere I saw a comment about winch sizing for 3x vehicle weigh. I carry this pulley in my after market glove box even with my 3500 winch. Your pics show a similar dump bed mechanicals as 10 golf cart boxes I picked up a while back Off Craigslist.
And again, welcome to the forum.
64899479 BF8E 45E9 8C5F 5D323CE4682D 4F144BF4 0A08 481F A1C5 BB921A4A02EB DC826BBC 8DB2 4B6A 993F 1F9CDA611466
Reactions: J80
W
wataboy
72
107
SoGA
Wow, I haven't really looked at the specs for the P-500/520 but I had no idea it wasn't the DCT tranny. Must've been a cost-cutting measure on honda's part. What a bummer. That means in manual mode you have to lift to shift, right? (although technically according to the DCT owners manual you should do that on those units also)
William
William
1,442
2,887
Flowood MS
No the computer cuts the fuel for you... #noliftshift
Reactions: trigger
Mudder
Mudder
11,691
88,486
Mine shifts better staying floored than going easy. But do wish it was dct.
William
William
1,442
2,887
Flowood MS
I remember on mine that when I shifted I would give it a little more gas and it was smoothest...
Reactions: Mudder
Mudder
Mudder
11,691
88,486
What are these for on the P520?
57EABEA0 D1D1 48A6 A61B 53DFDA602763
Reactions: Mudwing
67,170
Forget what they are called. But their job is to quiten down the intake.
The air intake resonator is simply an expansion chamber, a wide spot within a car's intake pipe. ... In effect, the air intake resonator, via its expansion chamber, slows down the air entering the engine. This reduces the engine intake noise and increases the amount of horsepower available.
Mudder
Mudder
11,691
88,486
Never noticed them on my P500, if it has them. Thanks, makes sense.
Reactions: Mudwing
W
wataboy
72
107
SoGA
I want cooling fins on my diff. 🙂 I wonder if it's because of the proximity to the muffler.
lee
lee
Village Idiot
2,402
13,602
Springfield Ohio
With all the complexity of the DCT I like the p500.
The way I see it, there are 2 areas of over complexity already.
The fuel injection is nice when it works.
But when it doesn't work I have no idea where to start.
At home I can bust out the manual and start reading but trail side that is no fun.
The other area of over complexity is the auto shift system.
It's using the same computer as the FI system (I assume) and again as long as it works fine.
But I hope the manual shift mode is still stupid simple like the early p500 that did not have the auto mode.
It's just a switch and a shift motor (and some other stuff) but I have a chance of understanding what is going on.
The transmission is a basic ATV manual gear box other than the shift motor.
Too my way of thinking, it's close to somthing I can understand.
E
edwardo
Alabama
Can someone tell me the width of the seat? Is it a bench seat? I'm wondering if two adults and one small child can fit.
Reactions: Backwoods
William
William
1,442
2,887
Flowood MS
Yes but tightly. I had to be careful not to elbow my kids in the face when I had mine...
