New lightbar install now machine does not start
Technoguru
Technoguru
32
37
58369431 F69C 4C67 B08D BB497DA8F4DD
Here’s a pic of the switch
Reactions: Plumber32
Technoguru
Technoguru
32
37
One set black and red go to light bar. One set of red and black connect to dead wire. It’s for cubes but I do not have them connected. Wires are terminated. White and blue go to switch.
2580933A 4507 4EF7 88C9 0C2806CC4694
HondaTech
Have you tried grounding it elsewhere, I recall another unit I worked on that was grounded on the battery and backfed into the system and caused issues.
Reactions: Mudwing
sharp
sharp
3,757
14,955
Tennessee
Is the battery fully charged?
Technoguru
Technoguru
32
37
I
tried grounding it elsewhere and here are my results. The engine starts up but the lights do not come on. There is no power to switch or lights
115,784
Have u tried a different relay? Maybe the one you have has an issue?
Your wiring looks correct tho.
HondaTech
Try grounding to the engine block, id say the roll cage isnt that good a ground for the circuit.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
take the ground wire off the middle of your switch and make sure the switch isnt grounding back through the light.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Start fresh and throw all the cheap s*** wiring in the garbage. Use a Carling switch and good 14ga braided wire. The switch will handle the light with no relay. Get some water proof connectors as well and carry on.
Reactions: Gorms and sharp
Technoguru
Technoguru
32
37
Ok, rewired front to back new switch works like a charm.
Thank you to everyone. I really appreciate all the help. You’ve convinced me I need to be a member. Thanks guys!
6E663ADD 712B 4629 8B0D 5BCDEF519C22
