P1000m5 New member here from WV
JerryWV
7
29
WV
View attachment 233601View attachment 233601View attachment 233602View attachment 233602View attachment 233601View attachment 233602
That it. I still say upgrade the switch but if you have your heart set on the original equipment I’ll send you this one. Just pm where to send it. It worked fine just not a great fit with The switch panel I’m using. Never installed used to check function.
Thanks, but I ordered a new switch and it should be here tomorrow.
JerryWV
7
29
WV
Mudder
Mudder
NTC/TAP Transition Member
11,766
89,351
Welcome from Ga. Regarding the location of a fuse or circuit breaker for a high amp wire you may add in the future, I put it close to the battery to protect all downstream wires in case of a chaffing short. The switched circuit breakers are nice to cut power when working on the circuit, and easy to reset if needed.
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
Welcome to the club from the mud holes of WNY. 😎
#ntc😉
Party on, Garth!🤣🤘🏾
