Ummmmmm 5 + 3 ,would be worse off than 5 + 2 !!!So there is nothing out there to keep me within 50 inches even if I go with a 5+3 offset. Well thank you for your answers.
I disagree with the above the 5+2 offset on a 7 inch wide rims with 10" wide tires or less will keep you within 50" width, even more so if you run 8" or 9" wide tires in the front.So there is nothing out there to keep me within 50 inches even if I go with a 5+3 offset. Well thank you for your answers.
ok guys here is the facts about this factory front wheels are 6.0in wide the offset is 4.5+1.5 that 4.5 is the inside measurement from the bead lip to the lug nut surface the 1.5 is from outside bead lip to lug nut surface if you install a 5+2 offset wheel the front will become 1/2 in wider at each wheel the factory rear wheel is 7.5in wide 6+1.5 offset 6in inside bead lip to lug nut surface 1.5in outside bead lip to lug nut surface a 5+2 wheel will make the rear 1in narrower at each side so if the machine is 50in wide on factory tires and wheels then adding 5+2 wheels will make the front 51in wide and the rear will be 48in wide if using factory tires if you install wider tires the width will increase by however much rubber is hanging over the edges of the wheels
Thank youok guys here is the facts about this factory front wheels are 6.0in wide the offset is 4.5+1.5 that 4.5 is the inside measurement from the bead lip to the lug nut surface the 1.5 is from outside bead lip to lug nut surface if you install a 5+2 offset wheel the front will become 1/2 in wider at each wheel the factory rear wheel is 7.5in wide 6+1.5 offset 6in inside bead lip to lug nut surface 1.5in outside bead lip to lug nut surface a 5+2 wheel will make the rear 1in narrower at each side so if the machine is 50in wide on factory tires and wheels then adding 5+2 wheels will make the front 51in wide and the rear will be 48in wide if using factory tires if you install wider tires the width will increase by however much rubber is hanging over the edges of the wheels
Well I appreciate all of the help. I could not find 5+1 offsets so I ordered STI HD4 5+2 and put Rip Saw 26-9x12 front and 26x11-12 rear. I know it will be close and if I have to I can put the stock rims on to go through 50" gates if I cannot make it, when I measured everything as it sits I should only be at 51", "so close but yet so far. I also ordered a SSS skid full Skid package, Rick is great and gives forum members a discount. A Strong Made Front Bumper and a 3000# Superwinch.
My pioneer is Red but I am looking into some vinyl covering, I would like to change it to a Gun Metal color. Any ideas or thought guys.
