P1000 New Pioneer 1000 Soft Doors?
brenton_B
7
15
nebraska
A friend was in Las Vegas and stumbled on to a expo of Honda showing of a couple of their newer models. He said there was a new soft cab they had on display on a Pioneer 1000. Did any one happen to get a picture of it or know anything about them?
Reactions: BWAF and sharp
322,675
They’ve had a soft cab set since it originally came out.
A077740A B68D 4433 AEFB 6A9458B6EDBD
Is it a different setup??
E
elkguide
3,377
7,964
Vermont
The fabric doors are different and quite a bit better.
Old stock number is 211 new stock number is 212
Would love to see pictures and hear from someone that has them.
tjoreo
tjoreo
1,025
1,975
Southern Idaho
I never had a chance to see the older 211 version but the 212 works very well. A friend of mine just put a set on and they seal very well on his P5 with 2 piece window and hard roof. The doors utilize a plastic piece with weather stripping that Velcro to the ROP. Then the doors attach onto a plate you rivet to the existing doors. This plate adds some rigidity to the door. If you do pickup a set, like the other Honda doors, work on fitment before completely riveting the plate in. The seal is great but the first door we put on rubs alittle on the back top corner, but I think the door bushing upgrade will fix this. We did better in the second door and it closes better. The only gap you have left is around the front and bottom of the existing doors but a little weather stripping could fix this. I was actually very impressed at how much an improvement they made to winter riding.
Sent from my SM-T350 using Tapatalk
T
tbaker
365
637
NW. Georgia
Look at sidexside enclosures on Facebook I think that’s it
BrentK
11
Troy,NC
I’ll try
My brother has the 212 doors on his I’ll try and remember to get some pics.
I personally like the combo of seizmik front doors and the Honda 212 rear doors the best but the textile is nicer on Honda doors. Zippers nicer on seizmik.
tjoreo
tjoreo
1,025
1,975
Southern Idaho
They only thing I didn't like about the seizmik doors is according to the directions, they attach to the factory doors with a piece of Velcro. I've never had much luck with Velcro sticking to off road rigs and especially when it's cold outside and you need doors. They look very nice and I believe there are a few on here that have them, so hopefully they will chime in.
BrentK
11
Troy,NC
No they bolt thru in the front of door and you drill a 5/8 hole in top of door at rear and run a steel rod all the way in door from top to bottom.
Very nice setup. The extra hinge really adds stability also.
They do have Velcro where textile laps over door but I’ve not even used it it’s not needed bc Frame fits door so well and makes a good seal
Now when I take them off in the summer won’t have Velcro left.
Reactions: BWAF
tjoreo
tjoreo
1,025
1,975
Southern Idaho
Thanks for the info. I'm hopefully looking to upgrade to a 1000 next fall and will definitely be putting doors on it. I will definitely look at seizmik doors when the time comes. Everything I've seen from them is top notch. It's good to have a few options. Thanks
Reactions: BWAF
brenton_B
7
15
nebraska
Here is a couple pictures of the new doors installed. It's just more rubber around the roll cage to help with the air coming in.
IMG 2919 IMG 2920
