New pioneer owner needs help with engine code 23
P
Partshouse64
Miami, FL
Hi
I just purchased a 2016 1000-5 that shows the check engine blinking code 23 (2 long and 3 short blinks)
Can someone tell me what that code means?
Any input will be much appreciated
Reactions: TxDoc and ChadD
YardDog
YardDog
Grumpy ol' fart
617
1,937
Arkansas
I think that's 02 sensor. Maybe check the wires to see if the connector is loose. Aside from the code, does it start and run ok?
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Here is what the service manual says
Capture1 Capture3 Capture2
Reactions: TripleB
russknight
russknight
1,910
7,511
Perry Florida
My 2016 1000-3 started doing this today. Noticed a minor loss of power running about 45 mph then noticed the 2/3 code flashing. It went away upon shutting off and re-starting, but the slight power loss is still present. I submerged the exhaust recently. Probably damaged the O2 sensor?
