P500 New pioneer owner
John Mc
114
252
Vermont
I went with the 66" poly blade from KFI for the plow set up on my P520. I was a bit concerned that 66" would be too much for it to handle, or that I would be limited to just doing light snows with it. I was going back and forth between the 66" and the 60". Very glad I went with the 66". The P520 handles it fine. It took a bit of digging, but I found a local KFI dealer in my area (a motorcycle/ATV shop)
Since I have larger than stock tires tires (27"x9"), I needed to order a leveling kit. The kit I ordered will do either a 1" or 2" drop. I forget which drop I ended up using, but it worked perfectly. The whole system was simple to install.
I do have a tractor with a loader on the front and a snow blower I can put on the rear for the really heavy snows, but the P520 set up is much faster.
Plowing with P520
____________________
I run square-link diamond-pattern chains on my rear wheels (better lateral traction than the ladder style chains, square link is more aggressive than the links made of round wire, but not as aggressive as the studded diamond pattern - so a bit more pavement and garage floor friendly.) I throw a couple of bags of tube sand in the dump bed as a counter weight to the plow. We have a 1/4 mile long driveway with one steep section. Most of it is gravel, but the loop up near the house was recently paved. That paved section is why I went with the square link chains. Had it not been for the paved section, I probably would have gone with their V-bar pattern chains or perhaps their alloy studded pattern chains. I got mine from Bluejay Industrial. The site shows the square link chain, but when you click on it, it says "There is currently no content classified with this category." However, they do in fact sell these chains, you just have to contact them via phone or email, since the web site does not show them. (Bluejay has a sister company in Canada that sells the same chains: Wesco ATV chains page. Their site shows the full chain selection.)
Chains:
P520 with Chains
210,528
Since I have 27"x9" tires, I needed to order a leveling kit. The kit I ordered will do either a 1" or 2" drop. I forget which drop I ended up using, but it worked perfectly. The whole system was simple to install.
Chains:
I see what you mean by the diamond chain, lots of biting edges. We don't get much gradable snow here.
John Mc
114
252
Vermont
I went through several iterations of chains on my tractor before engine up with the diamond pattern studded chains. They are the best for winter traction. I sometimes leave them on the tractor year round, since they provide much better traction when working in the woods: no slipping sideways on a side hill and getting stuck up against a tree.
I was concerned that if I spun the tires on the UTV, I might damage the pavement, so I went with the square link for the P520, since it's more pavement friendly.
Adams1122
Adams1122
11
47
Chains:
Thanks for ALL of this information! I’m going to start digging into all this now. I appreciate it, your machine looks great!
Reactions: Smittyp
John Mc
114
252
Vermont
If you regularly get deep snows, the poly blade is 5" taller than their steel blade, yet weighs the same. Poly also supposedly has fewer issues with snow sticking to the blade.
Adams1122
Adams1122
11
47
We can have pretty average winters here. But we can also get anywhere from 6-18 inches at a time. Poly seems like the way to go then from everything I’ve read!
Reactions: Smittyp
Mopower58
Mopower58
Unburdened by what has been!
86,180
745,062
Crystal Springs,Ms.
Welcome from Mississippi. Not much snow at all around here but someone who gets the white stuff can help you spend money!
#NTC
Buggyman
Buggyman
47,857
375,697
ne. ohio
Where did you get the enclosure? I have been searching for something like this since 2022.
Mine is a 2014 that I bought used in 2016. It is a Honda enclosure that was on it when I got it. doesn't seal really well and a little hard to get in and out of. I believe back then it was around $3500.00.
Buggyman
Buggyman
47,857
375,697
ne. ohio
https://alumilitearmor.com/products...ures-doors&brand=honda&brandModel=pioneer-520 I would see if this company makes what want. Suicide doors are much easier to get in and out and are easily removed for summer. not cheap for sure but I feel it's much better quality and function. hope this helps.
