New satv A arms and issues with camber
Dnavcrew
Owasso
Hi all new to the site. Last month I purchased a almost new 2019 talon 1000R. Have never owned any sxs besides some China crap gocarts in 09, always been a bike or 4wheeler guy. Anyway first weekend out I hit Disney OK. On the second day I ran into a low cut stump and bent my lower left A arm. Still drivable. When I got home I ordered a set or the super atv high clearance arms. Beside having to carefully remove the c clips from the bushings the install for the lowers went ok. Using the instructions though to measure 23 3/16’s was a pain because to me if you say “make
measurements to this and install” that should be it. Then they want you to check camber which involves more tools and Removals/installs. Because of what I do, I decided to check the camber. Right side took about 5 turns to bring camber to 0.5- At this point I re zeroed the gauge and the left is 2.5 + even before I started. I started to check the mounts, welds and parts for damage but all look and scale straight. I moved the left out until 7turns in front and 8 in the rear. This only resulted in a 0 camber. I ran out of time and patience and left it. I’m headed to little Sahara for the weekend but now I’m wondering how much thread is left in the A arm. Has anyone gone to this extreme to actually measure camber and had these issues?
1D02ACFA 3A9C 4F0E BE49 C70FD3EC6C52 13A66E47 25E7 4185 B943 28ED959BEE7B
Reactions: TripleB
Vondy
Vondy
1,610
10,709
Houston,OH
I bought and didn’t care for the super atv arms. Setting up was a pain and one side was screwed way in and the other way out. Sold and bought l&w arms. Provided more clearance and had no adjustment but setup was spot on. Also bushings came with and easy to replace compared to stock.
212,375
I agree, and such a simple fix. I got sick of taking the a arms lose to adjust the alignment.
SLOWPOKE693
SLOWPOKE693
2,022
7,839
Somewhere in Texas
Good to know!
I was considering their arms for my racecar so I could change/dial in the caster and camber settings for different tracks, but after reading the above comments I think I am going to pass.
