Just mounted up some 27 zillas with a manual tire changer from a local harbor freight. This is a great tool for stock steel rims. If your not careful you can scratch the rims easily. Great tool for cleaning out the bead if you get some wood or mud in it.
Yup, excellent tool! I have one mounted to the floor up stairs in the barn. Has changed many ATV, UTV, motorcycle and auto tires. The neighbors use it also. Bought mine at Harbor Freight years ago.
These do work well if you have room for it but if you are limited on space you can use a hand operated bead breaker and two tire spoons. Last set I installed this way took about 30 minuets from start to finish. I’ll try to find a picture of the bead breaker.
