P700 New to me ‘14 700-2 Build
KyleC
KyleC
102
155
Pittsburgh, PA
After the Mines and Meadows trip, the OEM seatbelts had to go!
599F78C0 A749 4478 B6EB C90052577C7A
Reactions: Backwoods
KyleC
KyleC
102
155
Pittsburgh, PA
Do you have any problem with the harness straps slipping down the inner bars?
I just installed them yesterday, so I cannot comment whether or not they will slip while driving and strapped in. I envision them slipping down possibly when not in use. When I strap myself in, and started adjusting, they did not move. I think I'm going to somehow clamp on either side of the strap. Like a pipe clamp, or something.
KyleC
KyleC
102
155
Pittsburgh, PA
Couldn’t pass on a deal. Added OEM hard doors. Also added a dual interior fan that plugs into 12v female. Going to test the doors (heat) out at Mines and Meadows Sept.14. Headed back to take the wife.
F4C2B0A0 E33E 4918 B629 2E5DA1151B7B
KyleC
KyleC
102
155
Pittsburgh, PA
First public trip with the wife at Mines and Meadows! No one injured. Proof that you don’t have to be going fast for something crazy to happen. Was at a bad angle, trying to power through some mud, hit a covered rock and on the side we went! Broken door mirror, and bent door latch c-clamp thingy. Nothing major, or expensive. Flipped it back and continued on our way! Love the P7!!
0E634065 B1CF 4C2C B685 4DF3F16EBB4A B8216A30 3698 48D0 9EDD 494C4920998F
KyleC
KyleC
102
155
Pittsburgh, PA
Just an update on the Beared Harnesses. They do slide on the bar, when in use, and when not. Easy cheap fix, Tusk Harness Retainer Straps! All you have to do is take the head cushion off, and grind a slot into the cushion support. Easy peezy, and the harnesses are locked in.
