P700 New wheels and tires!
Cdaily3
Cdaily3
Washington state
Ordered a set of 28 x 10 x 14 tusk terrabite tires and ITP steel wheels with a 5-2 offset. Excited to try them out, especially after only having put 120 miles on our machine.
4C7D803F 4AE2 4ECD 80DB 0508C6CA415E 7886043E CB92 4B47 B725 E29F7B97DD50 090ACBF2 1051 417E A898 7C63EC05F9CE
Cdaily3
Cdaily3
Washington state
Will do, I was a little worried about power loss so we will see. These tires and wheels are significantly heavier. 18lbs for the fronts and 15 lbs for the rear, so we will see.
Reactions: Backwoods
DBD
DBD
67
141
Pennsylvania
How's steering and power with 28's, do you have same wheels all around and 2"lift?
03mossy
03mossy
275
1,080
MN
  2. Other Brand
That looks great! Put any miles on the tires yet to give them a good test?
Mopower58
Mopower58
No reservations about no reservations
69,652
640,599
Crystal Springs,Ms.
Welcome from Mississippi. Nice looking ride.
Cdaily3
Cdaily3
Washington state
So after a weekend and 100 plus miles on the tires now I’m pretty pleased. So with 4 people in the machine doing steeper hill climbs is slow going but doable. With just myself or two people it’s much better. As for the ride at 35-40 mph it feels much more stable. Traction in rocks is awesome and love the extra ground clearance. With still having stock suspension all the way around the front doesn’t rub at all and the shock will bottom out. As for the rear it does rub on full compression. I will be doing some research soon on the commander/pioneer 1000 shock options to get a bit more travel and to alleviate the issue with running in the rear and to deal with the annoying front shock bottoming out.
D8EE8912 94A0 4924 984E 9859266E9BE0 B9FB33EF 6E53 4CA3 A5F6 CF6058848C91 BE6A34AD A00B 491C 88B4 464FE708D928
SmokinDtires
SmokinDtires
5
Wv
View attachment 214690 View attachment 214691 View attachment 214692
What are you doing with your stock 12in wheels? If they are the deluxe ones I’d be interested in buying them
JimmyA
JimmyA
1,644
5,503
Northeast texas
Good to hear that the fronts are not rubbing! My spare set of Mud Tires .! was going to go 28's but was worried. Thanks for you review.
JimmyA
JimmyA
1,644
5,503
Northeast texas
Maybe if you crank the rear to last notch, might not rub?
DBD
DBD
67
141
Pennsylvania
I just went 28×10×12 itp Blackwater evolutions on 5-2 12" rims with a super atv 2" lift and removed the sway bar link to give 4 wheel independent suspension. Very plush ride, only have the rear shocks set at the second lowest setting. I may make 1/2" spring spacers to put on all 4 shocks just to stiffen them up a bit, and of course who doesn't want another 1/2" ground clearance.
0724200043
Cdaily3
Cdaily3
Washington state
Nice I like that set up, I have cranked my tears up all the way and it still rubs. Will definitely be keeping my eyes out for a set of 1000 shocks for the front and rear.
Reactions: DBD
DBD
DBD
67
141
Pennsylvania
I just missed out on a set of commander shocks 2 weeks ago on eBay. They went for $350. Meant to bid at last minute but missed it by 8 minutes😤
