Talon New X model rotational squeaking noise from rear
highpocket74
highpocket74
2,164
7,154
Kinder, Louisiana
www.10-80dirtsports.com
New 19 model Talon X with about 50 miles on it. I noticed a squeaking noise coming from passenger side rear when running very slowly. Sounds like a rubber squeaking sound on something rotating. It's not the brakes. Anyone run into this yet?
Reactions: TripleB
K
kidamer
ohio
Mines doing it as well cant figure out where its comming from
I've had 3 Talons making a squealing noise at slow speed or constantly while moving.
All three have been fixed by lubricating or replacing the pinion seal in the rear diff. For whatever reason, they arent greased enough from the factory and rub on the splined collar.
K
kidamer
ohio
thank you ill have to take it see if thats it
Reactions: CPope
Randy1976
9
42
Indiana
Mine did it was the metal squeal tab on brake pad only at slow speed pulled it away and done just got bent or something
highpocket74
highpocket74
2,164
7,154
Kinder, Louisiana
My talon has since stopped squeaking without doing anything. If it starts again I’ll check those recommendations. Thanks.
Countryboy1000x
Countryboy1000x
Kentucky
Hello guy’s. My 2021 talon 1000x 4 just started the squeaking coming from the rear pinion. Did yours quit the squeaking on its own or did you have to make repairs??
Reactions: Isaiah
Countryboy1000x
Countryboy1000x
Kentucky
Okay. Good I know it sounds like rubber. Did start seeping oil at any time?
Reactions: Isaiah
TSchearer
TSchearer
0
Kutztown, PA
Hello all. I just bought a used 21 Talon X last week with 26 miles. Went out yesterday and put about 40 miles on it. I'm getting the noise from the differential area that does sound like it's coming from the pinion seal area under that metal flange. Can anyone help me with how you lubed the pinion seal and what you used? I would think it's something more in depth than spraying penetrant between the metal flange and the diff but maybe I'm overthinking this. I'd appreciate any advice... Thanks in advance.
Countryboy1000x
Countryboy1000x
Kentucky
Hello guy’s mine did it also. And I called the dealership where I bought it and they knew about it. It’s the inner rear CV joints on the axels they have to be replaced. It’s under warranty and they replaced mine.
Jhall244
37
129
NE ohio
What did you end up doing? Shoot some line in it or pull it and grease it. Mine started doing it yesterday. Just under 100mi
906UP
906UP
15,019
142,652
da Yoop
Don't expect a reply from this user, he had 1 post and was last active almost 2 years ago
