P700m4 Niche axles
Cyberjunk
Cyberjunk
Berserker
1,622
6,077
Crane Hill Alabama
Will be running a niche axle for the replacement of the drivers rear that I had broke the splines right at the outer joint. Axle looks well made and has a 2 year warranty . I am running 1 1/2 spacers EVO blackwater 27” tires and can am shocks . Will see if these axle holds up .
Russ989
Russ989
22,560
146,472
How is the new axle so far?
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
im wondering how he broke the axle that way . and does the niche have better articulation than the stock axles?
Cyberjunk
Cyberjunk
Berserker
1,622
6,077
Crane Hill Alabama
Well took the axel out this week end . I haven’t removed it yet to see what actually failed . Will be testing the 2 year warranty.
Moto27
7
Florida
I am riding 27 X 14 on stock axles. I ride it like I stole and have had good luck.
Reactions: Alan_Vander
Cyberjunk
Cyberjunk
Berserker
1,622
6,077
Crane Hill Alabama
Stock axels are really good . I did get the broke axel warrantied and should get it in a couple days . The stock axel broke the splines off the end , the joint didn’t fail. Have 1700 on mine on ya I beat not it hard. I actually took out both left side this weekend . The front was a all balls 6 ball. The right front I up graded to the all balls 8 balls and so far it is holding up. I did find the bind that full lock puts on the front axels are a sure to break if you try and turn hard while using the lock.
Reactions: ohanacreek
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
air pressure has alot to do with turning breaks. im still on stock axles and ran 27s for the 5 yrs. now on portals with 32s and only problem iv had is portal brackets cut a boot. everything else is like brand new.
Cyberjunk
Cyberjunk
Berserker
1,622
6,077
Crane Hill Alabama
8d0c15ecf6f14a0397862f33ba5e18a8
So the joint didn’t break the axel did . Niche did send me a replacement as soon as I filed the claim. The stock axel did the same that I broke. Run can am shocks and 27” blackwater EVO’s .
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
id say use some limiter straps on the commander shocks but that kinda break is more inertia style.
