P500 No Electric power
G
Gamgriff
6
Coronado, California
2015 500 I did a little wiring job and now nothing works but fuses are good. Cant check the 49 amp fuse because I can't remove it. No power to anything.
NTCPrezJB
NTCPrezJB
Retiring Member
112,972
976,266
Hidden
Did something spark?
Did you reconnect the battery?
What were you wiring on?
Reactions: Mudder
G
Gamgriff
6
Was working on a turn single kit. No sparks and I checked with a meter to make sure of no shorts to ground. The only connection to the machine wiring was I connected my relay coil to a red wire that was switched.
G
Gamgriff
6
The reason I can't remove the fuse is I do not know-how. Never seen one like that. One more fact is the output from the relay was not connected yet so the coil seems to be the only thing that was connected.
JsheII3
JsheII3
Long time listener.
339
1,534
Mississippi
My dads p500 is has a short in the ignition switch, itself. Nothing comes on, sometimes.
Reactions: Mudder
G
Gamgriff
6
My two daughters removed the ground wire from the battery that I installed and now everything is good. I am at a loss for the answer but will investigate.
