P1000 No reverse or low range
Mike740
Ohio
Hello, I have a pioneer 1000-5. Last week I had been riding, I put it in reverse and it didn't move. It grinds something terrible, so I did some reading on here and found this to be a common problem. I replaced the shifter low reverse, gear reverse drive, final drive low gear, and the front fork. Now when I put it in reverse it don't grind anymore but it won't move either. Forward gears work in high range but not in low range. What am I missing? Thanks
Bastardchild
Bastardchild
1,978
7,251
Orange Heights, fl
In the floorboard of the drivers rear seat there is an access hatch you can pop and there is a box lid under the access hatch. Pop the lid and you can adjust cables inside the box. Ive never opened it or had to do it myself, but maybe there is something that needs to be adjusted in there. If thats not it Im sure someone smarter than me will be along shortly with a better answer. Good luck!
Reactions: BWAF
93whitese-r
93whitese-r
56
116
Cincinnati ohio
How bad is it too pull the subtrans and replace the gears I think mine is starting to go out
Reactions: BWAF
93whitese-r
93whitese-r
56
116
Cincinnati ohio
How many hours or miles are you guys at who are having issues?
Mine has about 400mi on it and I did the old shift into low when it was cold and didn't notice it didnt shift all the way into gear showing the - symbol and it started clicking and finally slammed into gear so I'm guessing I'll be tearing into it here soon replacing that
Reactions: Plumber32
Jefferson87
Jefferson87
258
275
Northern California
  1. Talon X4
My Talon is in the shop with about 150 miles for the same thing. I'm not familiar with the shift gate on the P1k, but I think the shift gate is a poor design on the talon. It needs to be further from park and the gate should be smaller imo.
93whitese-r
93whitese-r
56
116
Cincinnati ohio
You talking about the gate at the shifter right ?
jruss617
Indiana
This is what I need to know lol. About to tear into mine. i have all forward gears high and low, just no reverse other than a grinding noise.
  • Wow
Reactions: Remington
115,818
Welcome to the forum and your first ever post after a full year! 🥳
so u must know the drill…
Pics Or It Didnt Happen!
What year and Milage is that machine that your sub trans needs to be cracked into?
Reactions: WagginTail
P1K5Dave
P1K5Dave
2,260
8,461
Petoskey, MI
@93whitese-r and @jruss617 there is a thread on servicing your sub trans. They'll run forever if they're kept in proper cable adjustment and you follow the full-stop-and-idle rule for shifting.
P1K5Dave
P1K5Dave
2,260
8,461
Petoskey, MI
Read everything, lots of good tips from the gang in there.
