L
Hi I’m new to the forum and glad to get all the insight and tips from everyone and I hope y’all have some for me on this matter. I have a 2018 Honda pioneer 700-4 and it quit running on me. Well first off it died and even with the key off the display stayed on. Got a ignition switch and fixed that problem. But still won’t start. It will crank fine. I have power at one of the wires on the back of the coil once the key is on so I knew the other side should be a ground trigger. I Hooke my test light to the positive post on the battery and the other end in the ground trigger wire at the back of the coil and unfortunately there is no trigger coming through the wire. Can any of y’all help me? Where does the wire go to? What could cause this? A bad ground somewhere? Does this wire go through a plug that could have bad connection? I knew the trigger initially comes from the ecm. Could it be bad? Is there a ignition interlock of some sort on this machine? And all fuses are good
