HondaTech
Valves seem to get noisy after the first oil change. There fine until you get clean oil in then they drive you nuts. These units have the crf style unicam. So they shouldnt need adjustment as often, I think the interval is 3600 miles?
@Hondasxs filters come out w/o draining the oil. Youll loose a little bit of oil, as alway but no need to pull the drain plugs. But the the smaller one only needs changed every 2 engine oil changes I believe. I'm not around a service manual to check. I believe Honda Has done their homework on this one, I can't wait to see this engine opened up to something bigger or possibly an atv.
