P700m4 NORTH EAST INDIANA SERVICE CENTER PIONEER 700
searlest
7
indiana
Can someone please give a recommendation for a good service center in the North East Indiana area
I am 45 Mile South of Fortwayne and 115 Mile north of Indy
My machine has 500 hours / 2000 miles
I only issue I have that i know for sure is the clutch is slipping when I first take off when the unit is cold.
After it gets warmed up slippage is no longer a issue?
William
William
1,442
2,887
Flowood MS
Let it warm up a little. Maybe 1-2 minutes with regular oil. I switched to synthetic and now idle for less than a minute and have no slippage. I wouldn’t take it in for that. They will just let it warm up, then drive it and say it’s normal.
Reactions: Backwoods
William
William
1,442
2,887
Flowood MS
If you are talking real cold... Like freezing temps. Let it warm to one bar on the dash temp gauge!
13,416
65,777
And check the oil level following the instructions step by step. I believe the 700 owners have reported slightly better performance when oil is right at the top of the range on the dipstick, maybe slightly overfull?
JimmyA
JimmyA
1,644
5,504
Northeast texas
Mine does the same thing, has since new! Now I start it and put in gear, wait with a little bit of throttle until it moves good to go! By the way Welcome to the board.
Backwoods
Backwoods
32,533
333,767
Douglasville ga
I always let mine warm up , it doesn't take but a couple of minutes here to hit 1 bar. It never slips.
ByronM
ByronM
173
347
St Charles, Il
Don't believe your clutch is slipping as there in not a clutch on the 700, there is a automotive type transmission and torque converter which is designed to slip up to a certain rpm. Make sure you are using the correct oil as unlike a car the engine oil is used by the transmission and like others have said make sure the engine is starting to warm up.
