Nutsert tool set
aauman88
aauman88
1,091
2,846
Somehow the Nutsert is a new concept to me and I already see plenty of uses for it so I want to get a good set to start with.
What’s everyone’s favorite setup for use on the Honda?
Are there ones that are made to work on plastic? If so has anyone successfully did away with the push rivets on the stock fender flares and other places it’s plastic to plastic?
First use will be for new skid plate I think. Seems like good place to use that style setup
Adam
Neohio
Neohio
Beast of the East
14,588
73,847
Painesville Ohio
I use the astro kit from amazon for setting nutserts.
My skid plate is getting weldable t-nuts this off season.
Reactions: JTW
They’re ok.. but have a tendency to spin on occasion. I bought he Astro like @Neohio
Neohio
Neohio
Beast of the East
14,588
73,847
Painesville Ohio
Screenshot 20190917 183909
These are what Honda provides when installing upper doors on the 1000. They also use a rubber well nut if you add plastics to a base model machine.
Tramguage1
Tramguage1
Texan
7,479
30,593
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I have the Smittbuilt that 4WParts sales. It's the double handle type. Very satisfied with it.
McMaster Carr Nutcert tools are much better than Northern Tool or anything you’ll find in a big box store.
I have a Right angle tool and a straight tool.
Reactions: Tramguage1
aauman88
aauman88
1,091
2,846
And for 1592$ you can have a cordless battery powered one :eek:
Reactions: JTW
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
If you want to be cheap just thread a bolt in with a washer and a nut on hold the bolt turn the nut and presto rivet nut installed cheap but slow.
Sheetmetalfab
Sheetmetalfab
2,177
13,629
Alaska
I just do this with a drill turning the bolt.
Fast and easy.
I should add I have a large nut that is slotted and holds the head of the insert from turning.
Reactions: GPR1500SC
Tramguage1
Tramguage1
Texan
7,479
30,593
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
If you guys would add a small roller bearing between the nutsert and the flat washer it will work much smoother
I have done this if only installing 1 or 2, but perfer to use the correct tools when doing multiples.
Similar threads
