![TxDoc](/data/avatars/m/18/18076.jpg?1558277870)
TxDoc
What many don't know is that you're not supposed to reuse a Nyloc nut.
I buy the blue and red in a dispenser that's thicker and won't drip, and will sit in the grooves uniformlyBlue loctite works best when nylocs aren't permissible
I do believe that is the factory motto unfortunately.Cross thread because 2 threads are better than 1
They apparently teach that at Honda assembly school!Cross thread because 2 threads are better than 1
#idontskiparoo!I do believe that is the factory motto unfortunately.
TWSSNothing beats welding the nuts in place lol.
This I knew, but I do reuse them frequentlyWhat many don't know is that you're not supposed to reuse a Nyloc nut.
Now that's impressive!You guys ever seen Nord-Lock washers? I've used them on a snowmobile Y-pipe that is notorious for vibrating its nuts off.
Thank you for sharing thisYou guys ever seen Nord-Lock washers? I've used them on a snowmobile Y-pipe that is notorious for vibrating its nuts off.
