OEM Honda molded fender flares are a thing...
G
GK1969
29
58
Ira, MI
  1. Talon R LV
Does everyone that installed these Honda OEM Talon Flares 0SF70-HL6-A01 still like them and believe they are better than the aftermarket versions (Mudbusters, etc.). Thanks for the feedback.
Scrappapotamus
The Scrappapotamus
799
4,324
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
I have them on both of my Talons. They do what they're supposed to and look great
IMG 0639 IMG 0636 IMG 0637 IMG 0633 IMG 0926 IMG 0925 IMG 0924 IMG 0929 IMG 0928
TerryH
TerryH
664
2,241
Springdale, Ar
I've been super happy with them. Much better coverage than I had previous and look way better.
worth the money in my book.
Prntckt
Prntckt
1,105
7,712
Altoona, WI
I have them on my Talon X4 and they really make a difference in muddy conditions. It does add some width to your rig, and I have had some issues with rubbing on tight 65" gates in Wisconsin. They are quite flexible so getting thru the gates did not cause any damage. I would install them again if I got another Talon. I think they look better than other non-OEM fender flares. Easily worth the extra cost in my opinion.
20230730 201413
G
GK1969
29
58
Ira, MI
  1. Talon R LV
Thanks for the Feedback.
ScottJ24
ScottJ24
82
227
Cresson, TX
Do these replace the stock fender extentions?
Reactions: GovtMule
Scrappapotamus
The Scrappapotamus
799
4,324
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
They mount on top of the stock fender flares through the same mounting points. There is a metal bracket for the rears that support the rears towards the rear of the machine
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Only drawback I see is if you frequent very narrow trails. Do the extend past the tires?
Reactions: TimG and Remington
Doogle
Doogle
216
312
Surprise,Az Cincinnati,OH
My thoughts are that most miss the area needing protection. I will probably make something for my front wheels. The front wheels throw mud and water out in front of your travel. Then you ride into the spray. Windshield or goggles need constant wiping. I think a flexible hard rubber fender mounted above the wheel would be best. Changing with wheel turning would be best. I may have some better ideas after this wine influenced post is reread in the morning.
