P1000 Offroad Armour aluminum upper doors
Moxdmguy
65
417
53
Lone Jack, MO
Looking awesome. I too have the forest edition. I really appreciate you taking the time to post about it. I’d like to not shave the roof and they mentioned that it could possibly be avoided if you utilize a small spacer to raise it. Do you see that being a possibility rather than shaving the roof? I’d do it if I had to but prefer to leave it alone. Thanks.
Thanks! And happy to help. You could possibly shim the roof up a bit and avoid cutting, but the doors “seal” on the top pipe so there needs to be a bit of clearance so they will close and open properly. I am guessing removed about 3/8 of an inch. If I were to do it again I would take a little more time for a cleaner cut.
I had previously cut into my roof on the rear for another project so the terror of cutting a high dollar piece of plastic had long ago left me….
Best of luck making your decision!
Reactions: ChadD
rockremoval
69
180
PA
Appreciate it. Im not afraid of shaving it down. I was just hoping to avoid that extra step if possible. My machine is at my other house in the mountains and most of my tools are at my other place. I have to lug tools to do anything more than a drill and bolt on job and was curious about what was needed for the install as I would be doing it myself. Looked easy enough from the video off-road armor posted.
Reactions: ChadD
Moxdmguy
65
417
53
Lone Jack, MO
I hear that. The install is straight forward. Getting the A pillars aligned and the push pins reinstalled is just an exercise in patience.
I used a dremel with a hand attachment/cut off wheel for trimming the roof. The bolts through the top bracket for the door were a bit long so I used the same tool to trim them off once they were installed.
Ogemaone
Ogemaone
Excellent! Keep us updated on the delivery condition, installation if you are doing it yourself and of course what your thoughts are on em . Thanks much.
Just got the email that doors shipped. Should be installing next weekend along with the factory hard mid panel. Installed the ice crusher heater so it will be nice to get it all sealed up.
Reactions: rockremoval
