P1000 Oil Change-Metal!!
A
ArTurf
26
11
Arkansas
Changed both motor and sub trans oil today. When I poured the used oil from the drain pan into empty containers there were lots of metal pieces, sort of looked like what you would see if you drilled metal, at the bottom. I'm thinking not good. Anyone ever see this after oil change?
43,567
Some metal is normal in break in oil, but if we're talking chunks...that's cause for concern. A pic would help?
Rut roe... pics!! And I think I’d run it another 100 miles and change it again.
Reactions: TripleB
hondabob
1,309
5,216
Prescott Valley, AZ
There will be metal after the break in period. A magnetic drain plug will look like this on the break in oil change and there will be lots of aluminum particles in the oil filter. On the second oil change a magnetic drain will be nearly clean.
0081
010
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
I assume you've ruled out the possibility of the metal already being in the pan you were using.
Reactions: JTW
A
ArTurf
26
11
Arkansas
Didn't think to take pics, like mama said stupid is as stupid does.
They weren't in the pan before change.
If I had to describe them I'd say spiral balls. If it were just small flakes I wouldn't be worried. I'll probably change it in a shorter period next time.
Wish I had thought to drain engine and trans in different pans to see which one it came from. I'll do that next time
A
ArTurf
26
11
Arkansas
Side note. I rolled it in a 6' deep ditch on it's side this morning. Pulled it out and all's OK.
No chance any oil drained out is there? I didn't think to check before I left it at duck camp 2 hrs away.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Well it doesnt sound very good, but if it's bad it wont take long to find out.
How many miles on the machine?
Reactions: JTW
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Did it appear as though the appropriate amount of oil came out of the machine?
Reactions: TripleB
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Yes, looked to be correct. Why do you ask?
Low oil could lead to issues. Have you noticed any issues with how the machine operates? How it sounds, shifts, drives, idles...
If it were me I'd put on a few hours or so and change it again to see how it looks. Its cheap peace of mind. I've had 2 machines and never had any metal shavings. Fine flakes are one thing but spiral cut shavings are cause for concern to me.
A
ArTurf
26
11
Arkansas
Haven't noticed anything unusual, will change again shortly and keep oils separate
cekkk
25
20
Nevada
This makes me think about changing my oil at 50 miles and 150 instead of just a hundred when my Talon arrives Friday. Any thoughts about doing that?
Rambo
Rambo
339
822
Southern Indiana
Follow the manual on break in, no hard accelerations for the first 15miles.
Then change oil at 100 miles or 20 hours....
I'm getting ready to change mine 103 miles and like 15 hours.
Reactions: cekkk
G
GWH
749
2,476
Las Vegas Nevads
If u let both the sub trans and engine oil drain into the same pan,then I would think most of the metal came from the sub trans.Next time use a separate pan,this way u can isolate ur concerns
G
GWH
749
2,476
Las Vegas Nevads
If you haven’t,make sure u change ur differential oils as well.the oil that came out of mine looked like metallic paint.refill w synthetic gear oil.made a big difference in how quiet the gear boxes are.
Reactions: russknight and JTW
