I changed my oil and filter for the first time for me today. The 1st service was done by the Stealer and I will be calling them in the AM! The first thing I found was the hardware to the access panel was overtightened so much that one of the ears to the cover was broken. I now get to order another cover to replace it. The drain plug was over tightened so much that the threads are surely stretched to almost stripped. The oil filter cover bolt was so tight that it took two hands to break loose. No doubt a torque wrench was not used at the Stealership as the drain plug was supposed to be 18ft lbs access cover 9ft lbs and filter cover 13ft lbs. There is a Stealership less than 25mi from me but when I purchased the 700, I traveled 235mi to purchase due to reputation and quality of service. The one nearest me sux as they have serviced my last two Goldwings and did piss poor work that I learned to service them myself, it looks like where I purchase the UTV won't be servicing it either anymore. By the way, I need another access cover to replace the broken one? Any Ideas
