I've got a 2021 X2 with 2800 miles. After the last ride I've found some oil in the air box (below the Trumpets). Doesn't seem to soak thru the filter so not a lot but enough I could see a small puddle in the area of the pix . I checked and the oil level is perfect. Did I add a little too much oil at last oil change or what would cause this?? Otherwise, no issues...
