P500 Oil in airbox?
The Green Goat
The Green Goat
2,069
15,058
Ohio
Not sure what to make of this, but I was doing routine maintenance today for the upcoming MOM ride and discovered my airbox has probably 1/2"+ of oil sitting in the bottom of it. I'm thinking, that's odd, and probably shouldn't be there. My memory sucks, but I don't recall ever rolling this thing over. I keep the filter cleaned/oiled/on tight. Seems to run as well as it ever has. Only thing I can think of is the crankcase is getting pressurized somehow and blowing oil out a vent tube somewhere and that concerns me a bit.
Thoughts? Did I flop this thing and am just completely blanking out on that memory? @futzin @KyGal83 ?
1000003805
The Green Goat
The Green Goat
2,069
15,058
Ohio
Ok, so it's more like 2". Air intake seems relatively clean, but definitely oil-free. There's the air inlet pipe that has some muck on it, but no oil to speak off. So I guess I'm not sure where it's coming from. Perhaps its a mixture of the filter oil and water?
1000003806
1000003807
KyGal83
KyGal83
8,650
85,710
Kentucky
Yikes... had that with mine, but it was in fact from a layover where I did not shut it off. Hopefully nothing major for you... @906UP or @Neohio ... any ideas?
On another note; I thought the 500 and 520 airboxes were the same.. but they aren't. Interesting.
TripleB
TripleB
14,118
123,571
Caryville, Tennessee
906UP
906UP
13,965
131,755
da Yoop
  3. Talon X
Pull over half a liter out of it. Engine dipstick seemed a smidge low, but nothing alarming.
Any chance you overfilled it a bit on the last oil change? Seems like a lot for it not to be low on oil.
Several things can cause this like too much oil in the crankcase, a dirty or too heavily oiled airfilter, extended high rpm runs, etc. I wouldn't worry about it too much. Clean it out and run it!
The Green Goat
The Green Goat
2,069
15,058
Ohio
Make sure the drain going to rr is clear as well. I used compressed air to blow this chunk out of that hose recently.
RR?
The 520 airbox is a bit different from the 500, from what I understand. That being said, the drain hole has a clear plug clamped over it. I pulled that off and cleaned out some mud that was caked in it. There is a vent tube that runs to the crankcase. I didn't pull that off yet, but probably will. If you can see that little square chunk of foam in my 1st pic; that's where the vent comes in. My assumption is that is where the oil was pulled from as that foam is soaked in oil, so I assume it's at least somewhat patent.
The oil on the dipstick was a bit inconsistent when checking. The first time I pulled it out, it was about 2/3 down the checkered area, but the more I checked, the further up the dipstick it got. I'm gonna add a half quart and run it.
The Green Goat
The Green Goat
2,069
15,058
Ohio
Don't think I overfilled it. Like I said in the previous post, it was a bit low, but I also kept getting inconsistent readings. I did heavily oil the air filter prior to TO24 and I do only run it with the pedal to the floor, so there's that.
Neohio
Neohio
Beast of the East
14,441
71,966
Painesville Ohio
RR?
There is a clearish drain hose on the 500. Remove the valve on the end, remove other end from airbox and blow it out.
KyGal83
KyGal83
8,650
85,710
Kentucky
As a reference, here are 2 photos on the inside of my air box. I have a drain hose/vent that terminates near the right rear tire, that was clogged when I took these last November.
IMG 5890
IMG 5891
futzin
futzin
3,975
29,397
Kentucky
I have nothing substantive to contribute but I will note this is the second time in recent days a tag has not resulted in a notification. Strange.
I know I'm unsocial, but still... 🙂
Has the machine leaned heavily to driver for a time with the engine running?
(near SPIM)
KyGal83
KyGal83
8,650
85,710
Kentucky
(near SPIM)
You unsocial? Never! (insert sarcastic giggle) …
KyGal83
KyGal83
8,650
85,710
Kentucky
You did have a SPIM in June.. in mine. (I should check my box, 🤔). I do not remember you flopping yours, there was a close moment on trail 11… but not close enough to warrant that.
