Dirtstiffs-1000
- Nov 3, 2018
- 1,554
- 5,658
- 113
- Ownership
1000-5
Yes, I did get a recall notice. I’m pretty far from the nearest dealer (and bought it from dealer 800 miles from me) — and I don’t have a trailer... so that’s why I’m considering taking a look myself. Then again, maybe this is an excuse to buy a trailerYes, basically.
Did you get a recall notice?
Let dealer do it and document, if so.
JMO
mine was f'ed.I just had mine done. Dealer says that about 2/3 of the ones they have checked have the boogered bolt upon inspection.
If your steering wheel is that far of and started off straight I would check you tie rods to make sure nothing is bent and that the jam nuts are not loose. I would also check the lock to lock to ensure the steering is centered within the steering rack. To pull the steering wheel is easy just pop off the Honda Logo and it is just one nut.
yeah I should have mentioned it’s all good underneath. It’s simply laziness of the tech keeping the wheel straight when the recal was done.
If that’s the case I would just make sure wheels are straight and then pull and straighten the steering wheel.yeah I should have mentioned it’s all good underneath. It’s simply laziness of the tech keeping the wheel straight when the recal was done.
