T
Hello All,
I'm in the process of researching my parts list needed for my second sub-trans rebuild where the customer's reverse has failed. I performed one of these repairs on a 2018 model last fall replacing the 27T reverse drive gear and the low/reverse shifter. At the time, I did not perform the Talon reverse gear change due to parts availability issues and I was informed that there may be some new/supercede part numbers in the pipe for the 2022 model year to possibly address perceived reliability issues with the sub-trans.
I have learned of the update/supercede for the shift fork shaft and the gearshift drum "star" that has been discussed in other threads regarding the sub-trans and updates and was planning to incorporate these pieces into my repair.
24210-HL4-010
24331-HL4-010
I started researching the 2022 model year P1000 sub-trans components and I noticed that there are a number of hard parts that have been assigned new numbers. This includes shafts, shifters, and final drive gears, low, reverse and high among others. It should also be noted that the gearing for reverse was changed to match that of the Talon gearset for the 2022 model year. (25T/22T)
So this gets me thinking, are these components interchangeable with the 2018 sub-trans such that I can accomplish the repair with updated part numbers and also achieve the desired gear reduction with the following parts for the reverse idler shaft, reverse drive gear and low reverse shifter?
23711-HL4-AJ0
23691-HL4-AJ0
23751-HL4-AJ0
Notice the same part numbers with the 2018 vintage parts with the exception of the AJ0 now in the part number sequence. As part of doing a sanity check on this I decided to check if the case used in the 2022 was the same as previous model years in an effort to gain some confidence if the new parts will work in the older sub-trans.
The 2022 Pioneer is now using the Talon case. This is throwing a wrench in my thought process, but knowing the interchangeability of the previous years Talon parts with the Pioneer, I'm still thinking the parts interchangeability would remain the same in these instances.
Does anyone on this forum have an intimate knowledge of these assemblies such that you could provide guidance that the 2022 Pioneer parts identified above would be compatible as a repair/upgrade for the 2018 unit I am working on?
Thank you in advance!
24210-HL4-010
24331-HL4-010
23711-HL4-AJ0
23691-HL4-AJ0
23751-HL4-AJ0
