P500 P500 Tire and Wheel pics
jmcampbell54
292
628
Texas
Ab8782e1293aa3f40ad3e347f65cdf4e42e47ebdba49a9b7b35e637c99dd5a922bdb46d8fafc9a393c0be080cb6dbde1
Interco Super Swamper blemish tires $189.00 delivered.
27x12x12 rear on 5-2 ITP beadlocks
27x12x9 front on 5-2 ITP beadlocks
Climbed every rock trail last weekend and powered through some thick nasty mud. Pretty happy with the tires so far.
iowaguy
iowaguy
624
1,425
Eastern Iowa
What’s the motivation to go to a 14” rim? Is it just that there are more 27” choices in that rim size?
Al
The reason I went with 14 is because when I got my 500 I wanted to get new tires and rims for it,I found set of new takeoff tires for $100.00 for the set of four,so I bought 14" rims ,that was 3900 miles ago and they needed to be replaced so I bought the new tires last month.If I was to do it again I would stay with 12" rims and go with 27" tires,I think more sidewall might improve the ride
Chuckerbird
97
302
53
Battle Mountain, NV.
STI HD3 wheels. 5+2 off set. Sedona rip saws. 26-9-12 frt, 26-11-12 rear. 25 inches high with 6 psi air pressure. 54&1/2 inches wide in the rear and 52&1/4 wide in front. No spacers and removed sway bar. Handles great in the mountains of Nevada.
IMG 20180421 132754184 PORTRAIT
RumpRocket
189
295
USA
I don't plan on getting any fancy rims when I upgrade, just a good set of tires ....26" or 27" ....I plan to wear out the stock tires first.
RumpRocket
189
295
USA
Reactions: Slim
AlR
AlR
470
1,166
Nanaimo, British Columbia
Just ordered a set of STI Roctane XDs for the P5. 26x9-r12 front and 26x11-r12 rear. Putting them on the stock rims. I ride mostly gravel and shale here so wanna try some tougher tires. The mudlites were getting cut up pretty good on the lugs. I'll transition the mudlites to the quad.
PS: 1" spacers on all four corners.
Al
Reactions: RumpRocket
Twangin
Twangin
131
276
NC
Where did ya get that rear box
The black box I built myself, and the aluminum box inside it I got from Lowe’s, made by BetterBuilt I think.
honda623
35
60
canada
what's it made out of
Sent from my SM-G930W8 using Tapatalk
Twangin
Twangin
131
276
NC
Its all made from untreated wood. Then I covered the entire thing with several coats of truck bed coating. Loving it!
Vaden01
Vaden01
126
299
Callahan, FL.
26x9x12 front
26x11x12 rear
Stock wheels 1.5 inch spacers on four corners.
Carlisle ACT. Great all around tires.
Reactions: Chooglin
KYhillbilly
KYhillbilly
562
1,713
Ashland, KY
26" Carlisle's on ITP Teflon coated bead locks. Will replace with a better tire once these wear out but couldn't pass up the deal. traded out factory tires and wheels plus $150 when i bought it. Someone ordered these with a deposit and never picked them up so i got a deal.
