G
This is listed as an item for initial maintenance. I’ve ordered the service manual, but it seems everything is on the slow boat these days. What should the idle rpm be? It sounds fine so I don’t think there’s an issue, just curious.
It’s pretty easy to wrap wire from tachometer around spark plug wire with yellow end reaching in front of back tire on driver’s side. I’m thinking actual rpm might be double what’s displayed here. There’s probably a setting on the tach…
